Announcements
Molecular Maya unable to access web resource when installed
When install the melecular maya plugin from https://clarafi.com/tools/mmaya/ to my maya 2019, it shows unable to access web resource to install mMaya, how can I deal with it?
patrick.schock
Autodesk Support
Autodesk Support
Hello @Anonymous!
Thanks for your post. Can you please send a screenshot of the error message? I would also suggest to contact the provider of the plugin,  Clarifi to sort out if the issue is known.
Thanks and best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Thanks for your reply, the error screanshot is as below.
post question here: https://clarafi.com/community/
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! Since this tool is not created by Autodesk, our ability to troubleshoot it is a bit limited. As @Anonymous suggested, it would be best to get support directly from the company that made the plugin 🙂 have you had a chance to post on that forum?
When you are able, please consider marking this thread as solved by hitting the "Accept Solution" button - this will help others find the answer faster 🙂
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
