Maya crashes when the cursor is dragged over tools
Maya crashes when the cursor is dragged over tools and then a the daiilog box starts to appear about the details about the tool and then suddenly maya closes.
patrick.schock
Autodesk Support
Autodesk Support
Hello @Anonymous,
can you please try to disable the Display Toolclip function in Maya at Windows > Settings/Preferences > Preferences > Help:
To find the cause of the issues, some more details would be helpful:
  • Which version of Maya are you using?
  • Which graphic card are you using? Could you update the drivers?
Looking forward to your reply if disabling the Display Toolclips could help to solve the crashing behavior.
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
jmosley
whoa - thank you - disabling popup help fixed it for me! I am on
MacBookPro - Maya 2020
I don't think I can update drivers (correct?)
High Sierra 10.13.6 (17G14019)
2.9 GHz Intel Core i9
32 GB 2400 MHz DDR4
Radeon Pro 560X 4096 MB
Intel UHD Graphics 630 1536 MB
Details on the Graphics card:
Intel UHD Graphics 630:
  Chipset Model: Intel UHD Graphics 630
  Type: GPU
  Bus: Built-In
  VRAM (Dynamic, Max): 1536 MB
  Vendor: Intel
  Device ID: 0x3e9b
  Revision ID: 0x0000
  Automatic Graphics Switching: Supported
  gMux Version: 5.0.0
  Metal: Supported, feature set macOS GPUFamily1 v3
Radeon Pro 560X:
  Chipset Model: Radeon Pro 560X
  Type: GPU
  Bus: PCIe
  PCIe Lane Width: x8
  VRAM (Dynamic, Max): 4096 MB
  Vendor: AMD (0x1002)
  Device ID: 0x67ef
  Revision ID: 0x00c2
  ROM Revision: 113-C980AL-075
  VBIOS Version: 113-C97501U-005
  EFI Driver Version: 01.A1.075
  gMux Version: 5.0.0
  Displays:
Color LCD:
  Display Type: Built-In Retina LCD
  Resolution: 2880 x 1800 Retina
  Framebuffer Depth: 24-Bit Color (ARGB8888)
  Main Display: Yes
  Mirror: Off
  Online: Yes
  Rotation: Supported
  Automatically Adjust Brightness: No
