Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
modelEditor1ViewSelectedSet
5 REPLIES 5
SteveHibberd
1567 Views, 5 Replies
So what is this in Maya 2023?
Every time I create something it gets put into this set!
What use is it?
5 REPLIES 5
Apparently, it gets created once you choose to isolate the selection.
Once you deselect the option, the set gets auto-removed.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
fishypants
in reply to: hamsterHamster
Its supposed to remove it but its broken in 2023 and will never get removed. Even if you open a new scene. Enabling Isolate Select once during a Maya session will make it so it can break for any scene you open until you close Maya and restart it.
iamzizo
in reply to: SteveHibberd
yes, it is never get removed from the current Maya session, I have to start a new session or make it Hidden in Outliner.
shimaguds
if someone is still annoyed by this thing, you can execute this line in mel, "isolateSelect -state 0 modelEditor1;", this won't solve the problem, but it will hide it in the outliner for a while, you can add a button on the shelf to do it quickly, tested in maya 2022.5.
shimaguds
in reply to: shimaguds
s
