As you can see I've got ViewCube at it's default in the ON position in every way possible, but it's not showing up. I'm a complete newb to Maya and am in an accelerated course so time is of the essence.
Noticed on some other posts that there's something called Viewport 2.0 and it's some kind of glitch in Maya 2015 and supposedly switching back to Legacy will fix the missing ViewCube issue?
How do I switch back to Legacy? What is Legacy? Why would Maya 2015 show there should be a ViewCube and not have one?
Hoping someone is able to help me as I'm trying to rig a character and it sure would be easier with the ViewCube. I don't even see why the ViewCube would ever be turned to the OFF position?
You all have been so helpful with me about so many other things that I hope you can help me here and someday I'll be able to pay it back to another person just starting out.
Thanks! Have a good one!
Sincerely,
Crystal
In the viewport select the menu Renderer/Legacy Default Viewport.
You may also change your preferences under Display / Viewport 2.0 / Default viewport: Legacy Default Viewport, so you don't have to switch the Viewport Renderer every time you start Maya.
Don't ask me why this is. It's the same in 2016, 2016.5 and 2017. Get comfortable with these unlogical behaviours, because there will be much more of this while you dig into Maya 😉
Best luck,
Marco
