Missing Polygon shelf
Ani_Sn
Ani_Sn
Hi
I just installed Maya 2016 and polygon tool is missing in menu set from the beginning. I tried to reset in the menu set but its not helping.
Can someone help with to solve this problem?
Replies (15)
Navigate to the user Maya prefs directory and delete shelves folder. After a restart all of the default shelves should be generates. If not, delete the entire prefs folder.
Windows: %homepath%\Documents\maya\2016\prefs
OSX: ~/Library/Preferences/Autodesk/maya/2016/prefs
Linux: ~/maya/2016/prefs
Hi Mike I got a similar problem to Ani.
I am old and behind the times... I have been using Autodesk 2013 for years... today, suddenly, my 'render' vanished from the shelf. Do I perform the same steps you advised to Ani?
I await your reply no rush, A kudos awaits you along with my deepest appreciation.
On my shelf, I still have general, curves, surface, polygons, subdiv, animation, dynamic, paint effects, toon, muscle, fluid, fur, hair, ncloth, custom, deformation.
Hi @Anonymous!
Yes, I would advise the same steps. You can always back up that folder to ensure you retain data.
If you are upgrading from 2013 to a newer version, I would recommend not importing preferences. If you have, I would suggest doing a complete prefs reset (just rename the prefs folder for the new Maya version) and restart Maya. The newer applications are very much not compatible with older versions.
Thanks a lot, MIke.I am obliged to you.
dickmove didn't work for me.
finally, I got my 20 yr old next door neighbor to do it for me....
...in exchange for a USB in the shape of Captain America.
yer same was a struggle got there though sweet xxxoxoxoxox
next time that Happens. Go to the tool icon (the wheel looking thing on the Left)  on your shelf tab and click on it. Their you should see an option that reads ( load Shelf) and click on poly Modelling
Holy guacamoly thank you SO MUCH!!!! I wasn't able to follow the first steps suggested at the top of the thread, but your solution worked perfectly. Thanks again!
halleckarts
Observer
Observer
You're a genius and I love you.
Halleck
tbass4X6HAL
Community Visitor
Community Visitor
Can confirm this does nothing now I don't have a shelf folder and I'm using a student license thanks a lot.
bryanGCYPS
Observer
Observer
Hey, It's been years since this post. But I had the same problem in Maya 2022.
It appeared that I scrolled down inside the shelf, and it looked disappeared.
So before resetting or deleting anything, check if you didn't scroll inside the shelf...
The self isn't even full of icons.. Yet, you are able to scroll.. Seems to be redundant and super confusing if you manage to do this unnoticed.
Hope this helps
nikunjrathore8623
Community Visitor
Community Visitor
I did what you mentioned that is I deleted, the entire prefs folder but when I opened my Maya application again, all my previous works were gone, what should I do now?
sathish_rD64VU
I have checked on that Shelf icon but didn't find Load shelf option in it. Then what can do?
sathish_rD64VU
While rendering I had faced an unexpected crash on Maya, so I reinstalled Maya. After that Polygon shelf tool is missing in shelf. How can I add it again in Shelf.
