Missing Menu Bar in Viewports
carperb
Message 1 of 11
carperb
This is the viewports without the menu setsThis is the viewports without the menu setsThese are the menu sets that I'm looking to get backThese are the menu sets that I'm looking to get back
Replies (10)
Message 2 of 11
sean.heasley
Hi @carperb
This is most likely an issue with your settings so a quick test you can try is deleting your settings/preferences.
Please let me know if anything changes!
Message 3 of 11
carperb
I am fairly new to Maya, I do not know how to delete my settings. Can you
advise?
Message 4 of 11
sean.heasley
Hi @carperb
Sure thing, you can find the steps on this link but I'll paste them for Windows down below as well.
The steps are:
  1. Use explorer to navigate to the following directory:
    C:\Users\USERNAME\My Documents\Maya\VERSION\
NOTE: If copy/pasting the path from above, edit USERNAME (custom username for the computer/account) and VERSION (version of the software in use) as appropriate​​.​​
  1. Locate the prefs folder and rename it to prefsOld.
  2. Restart Maya. If prompted to, select the option to Create Default Preferences.
Message 5 of 11
mspeer
Hi!
In Maya:
Preferences -> Interface -> Show menubar -> ...
Message 6 of 11
carperb
We tried this before I created this post, it did not work. Thank you
anyways.
Message 7 of 11
carperb
Thank you, I will try this.
Message 8 of 11
pawelU8995
shift + M
Message 9 of 11
thank you!
Message 10 of 11
THIS IS THE SOLUTION THANKS!
Message 11 of 11
fpapp0042PFENZ
Community Visitor
Community Visitor
thank you
