Hello, I saved my file to google drive and then downloaded it on my personal PC and the objects in the scene are dark grey. Does anyone know why this is?
Solved by loncy888. Go to Solution.
Solved by amaterasu-qbb. Go to Solution.
Solved by bpeterandall. Go to Solution.
your PC has different color management, check that. Maya>Preferences>Color Management
Hi! @bpeterandall .
Select the object and try Assign New Material in the marking menu in RMB in object mode.If this does not fix the problem, try changing the Preference or deleting the Preference file.
step 1: Windows->settings/preferences->Preferences->Color Menagement->Enable Color Menagement
step 2: Set the View Transform to ON.
step 3: Toggle the drop-down options to try different preview effects.
Thank you!
