Just installed Maya 2016. I was excited to check it out until Mental Ray will not put out an image! Loads the plugin without an issue, acts likes its rendering, and then renders black.
Maya 2016 & SP1
Mental Ray Plugin & SP1
Symptoms:
-In the new hypershade will not load mental ray preview.
-Tried deleting preferences, complete uninstall and reinstall of Maya, MR plugin, and Service packs with no luck. Same result.
-Tried brand new scene with single point light
-No alpha either
Any help would be greatly appriciated.
I think sp1 is causing the problem.
I just did fresh re-install of all and MR worked fine in 2016 and rendered black after SP1 install
Where did you find the mr sp1 plugin link? I can't find it. And you are correct, mr renders black however it acts like it is working times are as expected like 30 seconds. And I thought it was because I am missing the mr sp1 plugin. I think it maya sp1 that is the issue. I don't have mr sp1 installed yet.
Here is the link to the service pack.
I hope Autodesk gets this issue solved with sp2. Soon.
Use the link in the post above.
if you install the MAYA 2016 SP1, you also have to install the MENTAL RAY SP1, which is listed in that link.
This was not obvious to me until I re-read all posts and took another look at the autodesk link.
good luck
I tried it with both sp's and still getting black. I'm going to try without either service pack in the morning.
Instaled all service packs and new mr and still not working. Instaled Maya 2015, no updates.. and it works fine 🙂
