Maya UVs unfold together even when seperated.
When I select one shell of a UV and unfold all the other UVs that arent selected unfold with it. I dont know what to do. First time unwrapping stuff.
sean.heasley
Hi @Anonymous
The Unfold tool will unfold the entire model regardless of what you have selected.
The Layout tool however will only work on the selected shells.
If you can provide some screenshots I can help you with any other questions you may have.
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All is good. I guess it just bugged out that one time. I restarted Maya a
few times and then it fixed itself I think
sean.heasley
Hi @Anonymous
Hmm ok.
I'll mark this as solved for now but if the issue occurs again please update me here!
jacob.grossUWD2Z
Observer
Observer
The way I solved this was making sure the 3Dunfold plugin built into maya was loaded because for some reasons mine was disabled but once i turned it back on i was able to unfold individual UV shell again and also it improved the UV unfolding back to what I'm used to since its better then legacy.
