Maya UI Issue
Maya UI Issue
Maya UI Issue
I'm having this weird issue where Maya keeps creating this double Outliner situation:MAYA_UI_ISSUE-1.jpg
The only way I've found to be able to remove the second Outliner is to select 'Single Perspective' from the Hotbox menu, but when I do that, the contents of the first Outliner disappear and I don't know how to get it back:MAYA_UI_ISSUE-2.jpg
I've already gone through resetting the 'prefs' folder in my user documents folder a bunch of times already. Is this some weird bug? It's driving me crazy.
sean.heasley
Hi @Anonymous
This is pretty unusual and I haven't seen it before.
Does this happen across multiple scene files?
If you close both Outliner windows by right clicking on where it says Outliner and hitting Close tab then open one by going to Windows->Outliner what happens?
Please let me know if anything changes!
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
I have Maya 2018 and tried installing update 4. Hopefully it will clear up the issue, if it doesn't I'll report back.
sean.heasley
Hi @Anonymous
Did installing update 4 help at all?
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
