Maya Rotate Handle Issue
Hi can anyone answer what might be causing this issue? It one most of the lab PC's but not all. I have reset the Rotate and Maya setting/preferences. The pivot handles are all deformed, idk what the issue is.
mspeer
Hi!
This looks like a problem with your graphic card (/ driver).
I guess you use an embedded GPU.
- Try different Viewport modes / Render engine settings like "DirectX".
Or
- Make sure you use a proper 3D graphic card for Maya.
- Update graphic card driver (maybe just re-install after an OS update), or
- downgrade graphic card driver.
