Hello:
I have set up path along inside a narrow tube. I am trying to set up camera along the path traveling inside of that vessel. The tube diameter is only 2-3 mm. I am not sure what camera set up (focal length, angular range, zoom etc I need to set up) to view inside of the tube.
Greatly appreciate your help!
thank you,
Anil
make the tube any size you want, adjust the camera any way you want until it works for you, keep the original file in the dimension you want.
there’s a lot of room for cheating in 3D to get the job done.
best of luck.
Perhaps, I did not explain. I have tube already set. Can you give me some start up parameters for camera with such a small opening?
I tried several ways but the projection through camera is quite large.
thanks
Anil
