Hey all,
After several weeks of being in a rut with modelling I've started up the program again only to find that for some reason all of Maya has changed my language from english to japanese. Anyone had the same thing?
@Anonymous your title "Maya tower of babylon'd me (randomly changed language)" was changed for clarity by @sean.heasley
Hi @Anonymous
You can follow these steps and should be all set!
Let me know if this works or if you need more help!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
