Maya on Ubuntu 24.04
digitalRik
digitalRik
Hi there!
I'd like to ask for a solution to those who are using Maya in Linux Ubuntu 24.04. The compatibility reached Maya 2024, but from Maya 2025 on, I don't find any possibility to run the authorization module properly, and thus it doesn't even start. Some students whom I teach work in Maya 2026 and I can't open their files in previous Maya software. The error that appears when I execute Maya (even before the first screen loading the software) is:
maya: Autodesk MAYA 2026
A licensing error occurred that Autodesk systems were not able to handle for you. Please contact Autodesk Customer Support for help in resolving this error.
adlsdkAuthorize returned with error code: ADLSDK_STATUS_ADLS_NOT_FOUND
The default location for log files to help diagnose the issue is:
"/usr/tmp/MayaCLM-04-09-2025.log"
This is the content of the log file:
2025-09-04 13:03:19: ====== BEGIN MAYA CLM LICENSE DIAGNOSTICS (level 2) ======
2025-09-04 13:03:19: INFO: MAYA VERSION: Autodesk MAYA 2026.2
2025-09-04 13:03:19: INFO: Desktop Licensing Runtime Version: 9.5.0.53
2025-09-04 13:03:19: INFO: Desktop Licensing API version in Maya: 9.5.0.53
2025-09-04 13:03:19: INFO: initialize: GetInstance (Success)
2025-09-04 13:03:29: INFO: Received LicenseUpdateCallback for Maya 2026 (ADLSDK_UPDATE_REASON_LICENSE_UPDATE): NOT Authorized
2025-09-04 13:03:29: ERROR: Error Information: Maya 2026 : Unable to connect with the Autodesk Desktop Licensing Service to verify your license.
2025-09-04 13:03:29: ERROR: adlsdkAuthorize returned with error code: ADLSDK_STATUS_ADLS_NOT_FOUND
2025-09-04 13:03:29: ERROR: checkinLicense: unable to release authentication handle
2025-09-04 13:03:29: INFO: shutdown: normal exit
2025-09-04 13:06:37: ====== BEGIN MAYA CLM LICENSE DIAGNOSTICS (level 2) ======
2025-09-04 13:06:37: INFO: MAYA VERSION: Autodesk MAYA 2026.2
2025-09-04 13:06:37: INFO: Desktop Licensing Runtime Version: 9.5.0.53
2025-09-04 13:06:37: INFO: Desktop Licensing API version in Maya: 9.5.0.53
2025-09-04 13:06:37: INFO: initialize: GetInstance (Success)
2025-09-04 13:06:45: ====== BEGIN MAYA CLM LICENSE DIAGNOSTICS (level 2) ======
2025-09-04 13:06:45: INFO: MAYA VERSION: Autodesk MAYA 2026.2
2025-09-04 13:06:45: INFO: Desktop Licensing Runtime Version: 9.5.0.53
2025-09-04 13:06:45: INFO: Desktop Licensing API version in Maya: 9.5.0.53
2025-09-04 13:06:45: INFO: initialize: GetInstance (Success)
2025-09-04 13:06:47: INFO: Received LicenseUpdateCallback for Maya 2026 (ADLSDK_UPDATE_REASON_LICENSE_UPDATE): NOT Authorized
2025-09-04 13:06:47: ERROR: Error Information: Maya 2026 : Unable to connect with the Autodesk Desktop Licensing Service to verify your license.
2025-09-04 13:06:47: ERROR: adlsdkAuthorize returned with error code: ADLSDK_STATUS_ADLS_NOT_FOUND
2025-09-04 13:06:47: ERROR: checkinLicense: unable to release authentication handle
2025-09-04 13:06:47: INFO: shutdown: normal exit
2025-09-04 13:06:55: INFO: Received LicenseUpdateCallback for Maya 2026 (ADLSDK_UPDATE_REASON_LICENSE_UPDATE): NOT Authorized
2025-09-04 13:06:55: ERROR: Error Information: Maya 2026 : Unable to connect with the Autodesk Desktop Licensing Service to verify your license.
2025-09-04 13:06:55: ERROR: adlsdkAuthorize returned with error code: ADLSDK_STATUS_ADLS_NOT_FOUND
2025-09-04 13:06:55: ERROR: checkinLicense: unable to release authentication handle
2025-09-04 13:06:55: INFO: shutdown: normal exit
And my computer details:
Distributor ID: Ubuntu
Description: Ubuntu 24.04.3 LTS
Release: 24.04
Codename: noble
Intel(R) Core(TM) i7-9700F CPU @ 3.00GHz
32 GB RAM
NVIDIA GeForce RTX 4060 Ti
Using nvidia-driver-575-open (property).
I've done a research of some sites and groups and people is having the same troubles, with no reasonable answer for it. Please, could you help us running Maya under Ubuntu?
Thank you very much in advance.
99Firehawk
I'm sorry I don't have the answer, but I just want to chime in that I'm also on Ubuntu 24 and unable to install Maya.
Maya 2026: Was able to install, but hit the same error. I see on the install page it says "Please be advised that this installation method is incompatible with user license setups." which I'm assuming is the issue. Can I set up a license server for just myself? Or will Maya 2026 be updated eventually to allow user licenses?
Maya 2025 and older: Cannot complete all install steps, because libfam0 is not available on Ubuntu 24. Others may be unavailable too, but I haven't checked all the required packages.
