Maya normals BUG
Maya normals BUG
Maya normals BUG
BUG with normals with animation mesh.
video of a BUG
https://www.youtube.com/watch?v=cKwzy6wexow&t=1s
mspeer
Hi!
Please upload a scene-file (a cut down version should be enough).
file
_sebastian_f
didn´t look in your file but based on the video i would try to quad- or even triangulate the mesh before doing the bend. that way your normals should stay constant.
this BUG have a strange behavour in different versions Maya. 2018 have a BUG.
I find a solution for a time.  Turn on vertex normal and BUG is gone.  I can record a video with this situation. no need triangulation becourse I use a wire shader and need a quads polygons.
and please fix the Texture deformer.
mspeer
Hi!
I was not able to reproduce this behavior with your scene on a, so this problem seems to be related to your graphic card (/driver).
What happens if you render this scene in Maya Render View with Maya Hardware 2.0 and Maya Software?
