In maya mental ray there is three licenses local proffesional and network as im sure network means something, i just want it for myself so do i select local or does local mean something else and i know for 5 machines it installs if i select 5 whats the network option for then, so its question of network vs local i just want for myself and another computer i might buy later this yeah so i would want it in that computer too
thanks
Nikunj
Solved by DarrenP. Go to Solution.
pulled straight from that page you are referencing
Mental Ray Network License
This 1-year Network License is $395 per machine or $1,495 for 5 machines, and runs on any supported hardware. This license requires advanced networking knowledge to set up and FlexNet Publisher (license server application), must be installed and maintained for the licenses to function. License borrowing is not currently supported, meaning machines must be connected to obtain a license.
Network licensing requires Flex Net to run to serve out the licenses & requires the computer to be connected to the license manager at all times. Standalone or local means the licenses sit on each computer does not require to be connected to license manager sitting somewhere on your network
unless you have a server to install Flex Net on you would probably want to get a local licenses
DarrenP
I have a question about the NVIDIA rendering software licence.
Can someone explain me th diffence between the 3 License Type
Thanks for the answer, I had already saw that, but those explenations are not so clear for me.
I understand the difference between the local and the network licenence.
But why that huge diferrence between the local and GPU?
It's juste because it runs on any supported hardware for the first one and not for the GPU?
Thanks.
Denis
Hi!
It's just a rebate for owners of a NVIIDA PRO Graphic Card. This makes the combo of NVIIDA PRO Graphic Card + Mental Ray for Maya very attractive.
