Is it due to the size of your mouse pointer? Go to OSX System Settings > Accessibility > Display and change the mouse size to a smaller size (normal size or 1 tick past normal).
yes, in my testing I do see a difference in cursors between 2024 and 2025. In 2025 though when I use the target weld I click on the vert then drag to another vert and it successfully performs the target weld. Can you please provide a video of your issue occurring.
Thanks for the video!
The append issue is logged as MAYA-132962. In the meantime you'll have to use Quad Draw w/ shift key to repair holes (you'll need to run Mesh Display > Soften/Harden Edges afterwards though).
The cursor issue with the target weld I can reproduce but only when I increase the cursor size. When the cursor size is set to normal (in the OSX Accessibility > Display settings) I do not experience the issue. I will log a ticket regardless to catalogue the issue.
Thanks. Changing the cursor size just makes the problem less visible.
But with the "append to poly tool" (selecting poly edges) is quite frustrating.
I hope someone puts back the old cursor. Thanks for the log MAYA-132962
