Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya Mac 2025
8 REPLIES 8
Message 1 of 9
kielmaya
396 Views, 8 Replies
Maya Mac 2025
Maya Mac 2025 target weld and append to poly don't work.
8 REPLIES 8
Message 2 of 9
syracoj
in reply to: kielmaya
Is it due to the size of your mouse pointer? Go to OSX System Settings > Accessibility > Display and change the mouse size to a smaller size (normal size or 1 tick past normal).
Message 3 of 9
kielmaya
Thanks for the idea.  This is not it.
The cursor for the tools is incorrect.
Message 4 of 9
syracoj
The cursor to the tool may have been changed. But the append to poly and target weld are working on my side.
Message 5 of 9
kielmaya
in reply to: syracoj
did the cursor changed on your test? the 2025 cursor hot spot is not under the cursor and if it was it would not let the user see the vertex that needs to be selected.
Message 6 of 9
syracoj
yes, in my testing I do see a difference in cursors between 2024 and 2025. In 2025 though when I use the target weld I click on the vert then drag to another vert and it successfully performs the target weld. Can you please provide a video of your issue occurring.
Message 7 of 9
kielmaya
the screen recording also records the cursor offset from the location of the click.
Message 8 of 9
syracoj
Thanks for the video!
The append issue is logged as MAYA-132962. In the meantime you'll have to use Quad Draw w/ shift key to repair holes (you'll need to run Mesh Display > Soften/Harden Edges afterwards though).
The cursor issue with the target weld I can reproduce but only when I increase the cursor size. When the cursor size is set to normal (in the OSX Accessibility > Display settings) I do not experience the issue. I will log a ticket regardless to catalogue the issue.
Message 9 of 9
kielmaya
Thanks. Changing the cursor size just makes the problem less visible.
But with the "append to poly tool" (selecting poly edges) is quite frustrating.
I hope someone puts back the old cursor. Thanks for the log MAYA-132962
