Maya local rotate like 3ds max?
Hello!
How to rotate each component along its own center? maya 2017
Thanks!
 Thread title edited for clarity by @sean.heasley
sean.heasley
Hi @Anonymous
If you are looking to just rotate edges/verts you should be able to select them and see the gizmo in the center.
However if you're looking for the center of the object you need to go under Modify->Center Pivot
Hope this helps!
Please hit the Accept as Solution button if my post fully solves your issue, or reply with additional details if the problem persists.
Kudos are greatly appreciated. Everyone likes a thumbs up!
mspeer
Hi!
Select and rotate every component individually.
(Maybe make a script for this)
no. I meant the local rotation of each selected component like in 3d max.
3ds max
in Maya
sean.heasley
Hi @Anonymous
Like @mspeer said, you're best bet is to either move them all manually and/or use a script.
djonesuk
Hi
That's what transform component is for.  Select edges then click Edit Mesh, Transform and adjust the local rotation.  First click on the outer circle to make the rotation axes visible.
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Maya/fil...
sean.heasley
Hi @Anonymous
Did any of the above posts help with your issue?
