Announcements
Maya Hangs on Sequencer Play button
matto.schmidt
matto.schmidt
I opened an older scene in Maya 2020 (from a year ago) that I was working on in 2019 for quite a while.  It is a scene with a big set and 15 or so shots set up in the sequencer.  It worked fine back when I was working on it and now when I hit play in the sequencer it hangs Maya indefinitely.  I can scrub the sequencer timeslider without any problem and get realtime playback of the sequence, but as soon as I hit play it hangs Maya.  This is actually the first time I have tried using the sequencer in 2020.
  • Bugs
jordan.giboney
Autodesk Support
Autodesk Support
Hi @matto.schmidt
Thanks for posting! Are you finding that this crash also happens with new scenes, or just the specific file from 2019? Have you tried importing the file instead of opening it?
Whats your graphics card? Are the drivers up to date?
If this crash is tied to just your file, I would love to do some internal testing 🙂 If you would prefer to send me a download link in a pm rather than posting to this thread that would be great as well.
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
jordan.giboney
Autodesk Support
Autodesk Support
Hi @matto.schmidt
Just wanted to check in and see how things were going 🙂 Did you end up resolving this issue? If so, we would love to hear your strategy and mark this thread with a solution - this will help other maya forum members find their answers easier.
Thank you for being a part of our community!
Jordan Giboney
matto.schmidt
Hi Jordan,
My Graphics card is quite old (K400), and I have not updated the drivers in awhile.  I will try that.  I am not getting the same problem in new scenes.  I was versioning the scene, so I tried older versions, but I encountered the same problem.
I am not sure I can share the scene for legal reasons, but it is possible as the assets are all generic assets.
jordan.giboney
Autodesk Support
Autodesk Support
Sounds good @matto.schmidt! Definitely keep us posted 🙂
Another resource that may be helpful: Certified Hardware for Maya (graphics cards that have been tested and approved by our developers). Any cards that aren't on this list may result in inconsistent performance.
Jordan Giboney
lynn_zhang
Hello @matto.schmidt ,
Just checking to see if your problem has been solved. Did the response from @jordan.giboney help answer your question? If you find her suggestions helpful, please click on the "Accept as Solution" button in her reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
matto.schmidt
Sorry, I have not had time to test the scene.  I did update my drivers.  I will try it and see.  I am having similar issues with texture heavy scenes in the PR release as well.
