Maya file change to unknown format
I'm using maya 2016 and when i save my file to mb file, my format changed and i couldnt open it 😞
I may accidentally hit the button but I can't find it
Any solution?
My file change to this format:
sean.heasley
Hi @Anonymous and welcome to the community!
If you right click the file and hit rename, you can type out a name for the file and add .mb at the end for example "My_File.mb".
Also I highly recommend using underscores "_" instead of periods when you name files so you can avoid the risk of issues like this in the future Smiley Wink
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Thanks! problem solved Smiley Happy
