Maya - Fatal error (Attempting to save...)
Message 2 of 43
Hi team,
Hoping to get some help with Maya as I had it crash while working on a scene and now when I went to open it back up I keep getting a fatal error which says 'Attempting to save in .... Temp folder'.
I’ve tried deleting Maya and installing Maya 2019, tried opening Maya 2017. I updated my drivers and even renamed the temporary folder naming convention and I can’t troubleshoot the issue. I’ve looked up a few forums online and tried what they’ve recommended and haven’t had any luck.
Is anyone encountered this issue and can provide any options to fix it?
Thanks – appreciate the help
Replies (42)
Message 21 of 43
This worked for me:
Locate the prefs folder and rename it to prefsOld.
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Message 22 of 43
nyzhunav
Hi. You solved the problem since Maya?
Message 23 of 43
nyzhunav
Hi.
It did not help(
Message 24 of 43
Hi, yes,  I did this and it worked:
  1. C:\Users\<username>\My Documents\Maya\<version>\
Note: If copy/pasting the path from above, edit USERNAME (custom username for the computer/account) and VERSION (version of the software in use) as appropriate​​.​​
  1. Locate the prefs folder and rename it to prefsOld.
  2. Restart Maya. If prompted to, select the option to Create Default Preferences.
Message 25 of 43
nyzhunav
Help please!
Maya 2022_2 not working.
Send: Fatal Error. Attempting to save in /var/folders/82/m5ykkq92tb7swp_fwl1vdw0000gn/T/nyzhun.20211027.2315.ma
Message 26 of 43
25100118
Community Visitor
Community Visitor
Hi I have a Mac does this solution still apply and if so where can I find the control panel, thanks
Message 27 of 43
alfredo.siordia.g
Hi everyone. After you fix the "Maya - Fatal error (Attempting to save...)" with any of the solutions that are in this forum, do you were able to recover the files you been working? or, you had to do it again?
Message 28 of 43
rudihammad
Observer
Observer
I had the same problem(maya crash when closing session), and doing this solves it
MAYA_DISABLE_OPENCL=1
but if you disable OpenCl won't that be a problem if you wright plugins using OpenCl?
R
Message 29 of 43
carlcox62
Have the same, using 2022.
Message 30 of 43
ri8775v
Observer
Observer
same, I dont know what to do.
Message 31 of 43
djouad
Community Visitor
Community Visitor
Have you fixed it till now? Have the same Problem
Message 32 of 43
carlcox62
Hi, i fixed it. Just search this topic on youtube, there is a solution.
Message 33 of 43
rafaelsanchezaizcorbe
Hi, I posted the solution like 2 years ago I think. I don’t know if it will help you but or if you already try it.
Message 34 of 43
djouad
Community Visitor
Community Visitor
Already tried it. The thing is that I can create new scenes without a problem. After I restart the PC the fatal error occurs.
I already tried:
1. Your Solution from above.
2. Copy Text from a YouTube Video about the fatal Error into the Maya.env.
3. Deleted Maya 2022, installed Maya 2020.
4. Deleting the Maya Documents Path.
Nothing from these worked for me.
The Scene opens but I get the fatal error after 2Seconds.
Message 35 of 43
carlcox62
try this. open the maya environment file in editor found in documents/maya/2022.
copy this line and test one by one depending on the issue:
MAYA_DISABLE_CIP=1
MAYA_DISABLE_CER = 1
MAYA_DISABLE_OPENCL = 1
dont forget to save.
Message 36 of 43
nyzhunav
I have a problem. I can't log into the program, the following window appears, the photo is in the attachment.
Please help.
Message 37 of 43
djouad
Community Visitor
Community Visitor
A MASH corrupted my Scene btw.
Was able to delete the MASH Plug-In manually and import my model into a new scene.
Is fixed now.
Message 38 of 43
adelrio4571
Observer
Observer
thanks you are the best
Message 39 of 43
jadejaua1923105
Community Visitor
Community Visitor
Thank you so much. Saved hours of my time!
Message 40 of 43
jadejaua1923105
Community Visitor
Community Visitor
Thank you.
