Maya failed to finalize the color transform in linux
Hiii, this is bhuvanesh and i encountered an error while starting maya 2017 as Maya failed to finalize the color transform (in dialogue box ) and Error: The GPU adaptor of the transform to finalize is null(as popup below) after installing it in Ubuntu 16.04 and i have no prior knowledge related to this and i used the steps in this link to install maya in my ubuntu 16.04 https://www.linuxhint.com/install-autodesk-maya-2017-ubuntu/ . I use a Dell Laptop (Vostro 15 3000 series) with 12GB RAM and Integrated graphics . I have also attached the screenshots with this.I am passionate to learn maya so kindly help me on this.
sean.heasley
Hi @Anonymous and welcome to the community!
There's a few steps that may help fix this, however they may or may not work for Linux.
    1. Use a different server/viewer RealVNC will work
    2. Set viewport renderer to be DirectX not OpenGL
    3. Set the following Environment Variables either through a system variable or through the maya.env file found in the preferences folder:
        MAYA_CM_DISABLE_ERROR_POPUPS=1         MAYA_COLOR_MGT_NO_LOGGING=1
Let me know if these help at all!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
