Maya doesn't open
Maya doesn't open
Message 1 of 13
Maya doesn't open
Hi, my problem is that when I download Maya (2018) it works just fine, however, the next day, when I try to open it, it just won't initialize. I've tried everything but I can't fin the issue nor do I know how to fix this. Anybody has any suggestions?
Replies (12)
Message 2 of 13
sean.heasley
Hi @Anonymous and welcome to the community!
What are the hardware specs of your machine?
Steps to find your pc specs can be found here!
Are all of your drivers up to date?
Steps to update your drivers can be found here!
Finally, have you tried deleting your settings/preferences?
Message 3 of 13
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 13
Hi, sorry for the late reply, I haven't been able to fix it yet.
These are the hardware specs of my computer:
Processor: Intel Core i5-6400
RAM: 8 GB
Graphic card: NVIDIA GeForce GTX 950A
All the drivers are updated and I've already tried deleting the preferences but it only works the first time after installation. If I close the program and restart it only a blank window appears (labeled as "output window")
Any suggestions?
Message 5 of 13
sean.heasley
Hi @Anonymous
Hmm ok.
Can you try going to Documents->Maya->2018->Maya.env and add this line to it:
MAYA_OPENCL_IGNORE_DRIVER_VERSION=1
Then save the document and try to launch Maya.
If that doesn't work, you may want to perform a clean uninstall/reinstall of Maya.
Message 6 of 13
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 7 of 13
Hi, I tried what you said but it didn't work.
The problem is that after a clean unistall/reinstall Maya works fine as long as I keep it open, but when I quit the application and try to restart it Maya only opens a blank window
I have been using Maya with a student license in this computer for a year without any problems until last month
Do you have any other suggestions?
Message 8 of 13
sean.heasley
Hi @Anonymous
Have you tried running the program as an administrator?
Also, if you download an older version of Maya like 2017 does that show any issues?
Message 9 of 13
Yes, I tried running Maya as an administrator but it didn't help, Maya opens the first time but after closing it, it doesn't restart.
I haven't tried downloading an older version of Maya simply because my University uses the 2018 version so I can't use older versions.
Anything else I could try?
Message 10 of 13
sean.heasley
Hi @Anonymous
Have there been any updates to your machine lately like windows updates?
If so can you try rolling back those updates and see if Maya still works?
Also, does this happen on your universitys computers as well or only your personal machine?
Message 11 of 13
sean.heasley
Hi @Anonymous
Message 12 of 13
Hi, I finally found the solution!!
The problem was related to corrupted Windows registry keys as explained in the Autocad forum and the solution was to remove those keys using CCleaner:
https://forums.autodesk.com/t5/installation-licensing/autocad-2016-stuck-at-quot-checking-license-qu...
I followed the instructions of that message and now Maya works
Thank you for the suggestions
Message 13 of 13
sean.heasley
Hi @Anonymous
Nice work! Thanks for explaining what you did and marking it as the solution!
