Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
maya doesn't load my hotkey set at startup
12 REPLIES 12
Message 1 of 13
12094 Views, 12 Replies
everytime I start Maya it revert back to default hotkey set, I have to open hotkey settings and select my own set again, any help?
12 REPLIES 12
Message 2 of 13
macleanchr
Yeah, they broke this.  Until they hotfix it in a few months, you can force this to load your hotkeys by adding a userSetup.mel text file to your ".../maya/2017/prefs/scripts/" folder (if you don't have one already. If you do, just add this to the bottom of the file).  Open that file in a text editor and add the following:
hotkeySet -e -current *whatever_you_named_your_hotkey_user_file*;
For example, mine is:
hotkeySet -e -current chris;
Oh Maya.
Message 3 of 13
in reply to: macleanchr
Thanks that worked for me
Message 4 of 13
OBSERVATION:
In my case the name of the hotkey set file was "userHotkeys_Maya_Default_Duplicate" but I had to use the following code:
"hotkeySet -e -current Maya_Default_Duplicate;"
Message 5 of 13
mareknaprstek
Thanks! It was driving me crazy. Just found the userSetup.mel in ".../maya/2017/scripts/" instead of ".../maya/2017/prefs/scripts/"
Cheers
Message 6 of 13
Tags (1)
Message 7 of 13
mehdiablo
Making hotkeys more complicated to set... not a smart move autodesk
Message 8 of 13
_sebastian_f
in reply to: mehdiablo
@mehdiablo update your maya the bug is fixed for quite some time now. what @Anonymous  posted is actually a very nice new feature and was a workaround.
Message 9 of 13
in reply to: _sebastian_f
Here it is in python in case anyone is using a userSetup.py file.
from maya import cmds
cmds.hotkeySet("HOTKEY_SET_NAME", e=1, cu=1)
Message 10 of 13
Yes! Thx
Message 11 of 13
I am experiencing this in the latest version of Maya LT.
Message 12 of 13
conkerz
The above script solution works.
Another solution is to link a hotkey set to a workspace as shown here:
https://youtu.be/k2oKSU2ww8s
Message 13 of 13
in reply to: conkerz
Late to this thread but I was searching for solutions to this.  The way I've done this is to copy these files from a backed up copy of your prefs.  Worked for me today.
/maya/2018/prefs/hotkeys/
     userHotkeys_*.mel
/maya/2018/prefs/
     userNamedCommands.mel
     userRunTimeCommands.mel
Technology Administrators
