Message 1 of 24
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
If you use "T" mode on the Display Layer, you need to see Wire, but you can't. There's a kind of gray necklace that you see on that person's neck. Although I thought I made a wrong layer and made a cube and pressed the button on the far right of the layer to insert the object, the wire was not visible in Object Mode. But in Wire Mode 4, I was able to see that it came out properly. What's the problem?
