Solved by sean.heasley. Go to Solution.
Hi @Anonymous
This could be a driver issue with your GPU.
What GPU are you using and is the driver the same as our certified hardware list?
You can find our certified hardware list here!
Let me know if anything changes!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
Hi @Anonymous
While the drivers are up to date, do they match our certified system requirements?
You can find our certified system requirements here!
Also a simple fix you could try is deleting your settings/preferences.
All the best,
Sean Heasley
Hi @Anonymous
All the best,
Sean Heasley
