I've never had this happen before- is there any way I can recover my previous save? I did not save it on crash but for some reason it looks like I did. Additionally, I didn't increment and save and so I'm worried I may be screwed here. Any thoughts?
Solved by teddude75. Go to Solution.
I understand that, but meshes are missing from the scene in the outliner- I don't want to have to recreate everything, I want to be able to revert back to what I had.
It oddly kept some of the super old stuff but nothing that I've recently done 😕 and all the shaders in the hypershade are gone.
here's where the file saves at crash time. If it's not there then it didn't save. C:\Users\YourName\AppData\Local\Temp. If you have a pervious version that had shaders then your good. Also if you have textures just apply them again.
Thank you for trying to help- out of curiosity, right under my Maya file is this document -- the timestamp looks the time of my previous save; however, its got an 'mbB7zQbY' extension. Is there any way I can recover this file or use it somehow?
Try to change the exstension to .ma (not mb). If your lucky to will open. Also, for the future save .ma because you can editor the file and mb are binary
