it is windows8 64 bits.i can't send anything to mudbox.The button is available,but when open mudbox ,there is nothing.
Windows 7 Pro 64bits, same problem:
1. OneClick.mll is ON.
2. Maya 2014 sp2 send to Mudbox 2014 sp1
3. Connected to Mudbox ... and Mudbox is Starting ...
4. nothing
5. check maya log
2013-08-25 16:24:48: : Export: G:/Users/MyName/Documents/maya/projects/TEST/untitled.fbx
6. Maya.2014.1.64.syncfg:(The path is correct.)
<?xml version="1.0" encoding="UTF-8"?>
<SynHubConfig SchemaVersion="1.0">
<Application
Name="Maya"
StringVersion="Maya 2014 SP2"
NumericVersion="2014"
ExecutablePath="F:\Program Files\Autodesk\Maya2014\bin\maya.exe"
Architecture="x86_64"
</SynHubConfig>
7. Mudbox.2014.0.Windows.64.syncfg:(The path is correct.)
<Application
Name="Mudbox"
StringVersion="Mudbox 2014.0 SP1"
ExecutablePath="F:\Program Files\Autodesk\Mudbox 2014\mudbox.exe"
</SynHubConfig>
4. nothing
5. check maya log
<Application
Name="Maya"
</SynHubConfig>
<Application
Name="Mudbox"
</SynHubConfig>
You can check Mudbox log. It record all information. And you could find what's wrong when you received the fbx file.
Is this bug fixed in last Maya SP2 update? I can't use Send to feature in any of my ECS 2014 apps because I have it installed on different partition(and not default C).
You may have already solved your problem but just in case, I found that if you launch Mudbox and its open, as well as Maya at the same time, when you send a model to Mudbox, the connection works, but if you just try and send a model from Maya and Mudbox is not open, it will just get hung up and not play nice together. Hope that helps.
i can recreate the problem when i turn of internet access for maya
maya cries "could not save project" and crashes.
its working without problems as long i open internet acess for maya
I have the same problem. Mudbox and Maya are updated, but Mudbox won`t send to Maya.
I want to rigg this alien I created in Maya as I understand that 3Ds Max (have the same problem) is not the ultimate rigging-tool and Maya have become the standar today. Hope someone have a fix 🙂
Funny.
I posted this exact same problem a few months ago and got almost nothing in response.
I am using Maya/Mudbox 2014, I have then both installed on my premiary drive, but I am using OSX, and not Windows.
MB
Funny.
MB
Hope they fix this soon. Its a very handy feature 🙂
