AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Maya 2024 some HotKeys not working.
tgoreart
Message 1 of 17
tgoreart
Recently many of my most commonly used hotkeys aren't working and I can't figure out why. I've shutdown and restart as well as made sure the caps lock wasn't on. Any idea what could be causing this? Or how to resolve this issue?
Hot keys not working:
R (Scale)
F (Frame selection)
B (Increase/decrease brush/soft select radius)
H (Toggle visibility)
Spacebar (4 screens toggle)
Replies (16)
Message 2 of 17
amaterasu-qbb
Hi! @tgoreart .
I'm sorry to hear that. In my case, when this happens, I first save the data and do a backup of the preferences, then delete the old preferences folder.
If this fixes it, you know that Maya has a bug or something that causes the hotkeys not working itself,
This is just my speculation since I have no more information, but it could be that the keyboard you are using is malfunctioning. I would consider the possibility that you spilled a drink on it, or that the contacts have been desoldered. If you open Notepad to try it out and type text into Notepad, do you see any input or chatter? Does it work with other keyboards?
I hope this helps.
Bests,
Message 3 of 17
tgoreart
THanks but no luck. The weird thing is that the keys work just fine with everything else so I'm pretty sure it's not the keyboard.
Message 4 of 17
tgoreart
Also, 2023 runs just fine.
Message 5 of 17
amaterasu-qbb
Hi! @tgoreart .
Hmm. Maybe this is caused by the state of your Hotkey Editor. If a key is valid, it will be displayed in green. If it is not valid, it is grayed out like this.
What is the Hotkey Set selected in the Hotkey editor?
Maya hotkeys cannot be imported from MEL, they have to be exported from the hotkey editor and imported into the new Maya hotkey editor to be used. Sorry if you have already done this.
And one more thing. What version of Maya are you using, 2024.0.1?
I believe a checkbox during the initial installation asked if you want to load your custom preferences and use them. Did you check the checkbox?
In some cases, you may need to uninstall and reinstall Maya 2024. Right now you can install a new version of Maya, Maya 2024.1.0. You can upgrade to it if you like.
Here is a summary
  • Check the hotkey set of your Hotkey Editor and see if your key is displayed in green or not.
  • Close Maya, delete your old preferences and restart Maya.
  • You may need to uninstall and reinstall Maya 2024. or upgrade it.
Bests,
Message 6 of 17
seith43MSH
Just confirming custom hotkeys are indeed broken in Maya 2024.2.
Also the hotkey system gets confused by switching to/from object and component mode: A shortcut/hotkey that works in object mode will not work in component and vice-versa.
Needless to say, Autodesk, I'm not happy about this...
Edit:
Reverting to Maya 2023 until this mess gets sorted out.
Message 7 of 17
trung.nguyenquangMPFQW
Finally, found someone has the exact same issue. It's just so annoying, and it was not even some of my custom hotkeys. Bunch of default Maya's hotkeys like Ctrl+C, Ctrl+X and Ctrl+V didn't work at all on 2024.2.
What happened? anyone at Autodesk keen to look into those?
Message 8 of 17
Tested the latest 2025, not working either. Can anyone here please help?
Message 9 of 17
6064235
in version 2024.2, I set the shortcut ctrl+x for DeletePolyElements and it doesn't work. Back to version 2024.0.1 and it works
Message 10 of 17
Not sure how long we have to scream until this reaches Autodesk. I understand that they just care about enterprise s and studios. Ironically, we are the individuals in those studios who actively utilize their product, yet our voices are being ignored. Even though we were excited to give their new features a try, those showstoppers put an end to it.
Message 11 of 17
6064235
I want to send them an email, but I don't know where to send it. just in the forum, I don't think they will read it
I use blender sometimes, so I changed a lot of maya shortcuts, but after 2024.2, they won't work anymore.
Message 12 of 17
syracoj
Something to possibly try is to unload the lookdevx plugin (if you aren't using it that is).
Message 13 of 17
Gosh, it worked. My man, much appreciated. I guess that they have bunch of internal teams work on different features and didn't communicate very well to each others.
Message 14 of 17
luisandro.garza
Here we are in 2025. Are there any fixes yet? My custom hotkeys, mainly Ctrl+W, won't work on cycling cameras. I had all my macros set to my mouse, and it just stopped working.
Message 15 of 17
amaterasu-qbb
CTRL + W works as a shortcut to quit an app in many applications, and Autodesk Maya is one of them.
Use the hotkey combination of either SHIFT or ALT.
Best.
Message 16 of 17
amaterasu-qbb
Hi! @tgoreart .
Sorry for the slow response. I just came up with the idea of assigning an all new Hotkey Set in the Hotkey Editor, or try selecting the default in the gear symbol.
I hope this helps.
Best.
Message 17 of 17
luisandro.garza
Yeah, that's what I did, but we shouldn't need to change hotkeys to make
things work properly. It must be something with that combination of key
inputs.
