[Maya 2023]Green mesh appears when using bridge and add divisions
sin08164
Message 1 of 10
sin08164
Hello, I'm using Maya 2023 and having a problem with bridge.
If I apply Bridge and add Divisions, the newly divided face's texture disappears and mesh turns green.
Re-applying the material fixes the problem temporarily but I need to reapply the material every time I bridge.
Can anyone help me fixing this problem please?
※There is no problem with Maya 2020 version. This problem only occurs in maya 2023 version.
Replies (9)
Message 2 of 10
damaggio
Works correct here.
Message 3 of 10
p.brenner
Community Visitor
Community Visitor
I have the same problem
Message 4 of 10
damaggio
That is a logged bug and should be addressed in the next update.
Message 5 of 10
ahmed_m_niz
Community Visitor
Community Visitor
same here, any updates?
Message 6 of 10
damaggio
no, still only works with Linear path.
Try to bridge in Bender and import back onto Maya.
Message 7 of 10
man.in.kuwait
☹️Me also get the same problem in maya2024 I get green color when I connect 2 edges using bridge tool
Message 8 of 10
damaggio
It sucks hearing that is also broken in2024 and not addressed in the last update.
Message 9 of 10
alexandra_gutierrezdelacruz
Community Visitor
Community Visitor
I solved this issue assigning a material on the green faces. You can also select the whole object and apply an existing or new material. Hope it works for you !!
Message 10 of 10
damaggio
That's not a solution is the recommended workaround  , however this needs to be fixed in 2023.
Please those in 2025 let us know if the issue does not happen there.
