MAYA 2022 ERROR when using full screen and pressing spacebar on a Mac
Message 1 of 28
Hello, I haven't been able to use Maya 2022 since each time I Enter Full Screen I can't even press Spacebar or use the hotbox because all the screen goes dark grey or black right away.
Here I attached a screen recording of my problem since I can't even explain it well, hope there's a solution to this:
Replies (27)
Message 2 of 28
BaardArnesen6185
I have the same problem. I cant use Maya 2022 because of this
Message 3 of 28
marin.goleminov
Same problem. Latest Big Sur, Maya 2022.
Are You guys on Intel or M1 macs?
Just curious if this is a general Mac thing or just some M1 incompatibility.
Message 4 of 28
BaardArnesen6185
m1
Message 5 of 28
same for me in mac
Message 6 of 28
could you please help  to resolve this issue ?!!😓
Message 7 of 28
taka_frint
Yep, the same problem too.
MBP 2018, Maya 2022
Message 8 of 28
nelsoncruz
Hey,
we are aware of the issue and hope to have it addressed shortly.
Cheers
Nelson
Nelson Cruz
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 9 of 28
The same problem here
M1
Maya 2022
Message 10 of 28
I also had the same problem with macOS Catalina on a MacBook Pro (Retina, 13-inch, Late 2013). I still have the same issue even after an update to Big Sur that I have made recently. I am using educational licence.
Could you please help on how we can resolve the issue? Please let me know if any solution exists.
Thank you
Message 11 of 28
marin.goleminov
Just recently I noticed that on Windows, too, full screen mode + Hotbox does some weird stuff. Not as bad as on macOS, but noticeable.
Is there an ETA for a bugfix? I do care about macOS a lot more than Windows, but if both are affected You'd get even more karma for fixing it 😉
Message 12 of 28
marin.goleminov
@nelsoncruz any news on the topic? A bugfix release would be much appreciated.
Message 13 of 28
Surely the same problem. Got separated white screen with the general maya hotbox while after "spaced". But. When i switch in-between screens like from "dead maya" to desktop or something and then back to maya, i get usual maya screen. This is a trick to return to ur work immediately in such a situation. So, what i recommend now is not to use hitting space key anyhow for god's sake. hope yall got me.
Message 14 of 28
I thought i was the only man who got this bug. Hope it'll get fixed soon.
By the way, I wonder: how do i use regular alt + mid mouse button with mac trackpad or something?
If u got a solution, please reply. Best regards.
Message 15 of 28
oscarV44A8
This was fixed for me in the latest version.
Message 16 of 28
Same stuff.
Message 17 of 28
rpatterson602
Community Visitor
Community Visitor
has this been fixed? or is it still being worked on
Message 18 of 28
BaardArnesen6185
I hope someone is working on this. Still the same problem in full screen. It changes to the next screen... I use an older Maya version, and is still waiting.
Strange that no one can make this work.
Message 19 of 28
marin.goleminov
This was fixed in the last update of Maya 2022 for Mac. If You install the update, the issue should go away. Unless You have a reason to keep the older version.
Message 20 of 28
BaardArnesen6185
Well. This is not true for me.
I have the latest version for mac. The problem is a little different. But spacebar in full screen, makes the screen shift to the non-full screen to the side.
So no, it does not work.
I will test os upgrade.
