Maya 2020 Wacom Right Mouse Button is not working
mayanim8
Message 1 of 49
mayanim8
I am on a PC
Windows 10
Nvidia Quadro M2200/PCIe/SSE2
Maya 2020.1
For some reason Maya 2020 will not recognize the Right Mouse Button on my Wacom Tablet Pen Intuos Pro.
All I get is a circle with the mouse arrow Icon.
I can get the Functions to work as a Right Click, however as soon as I bring the pen onto the tablet it does not work.
I have tested this with a different Intuos tablet and get the same results.
This appears to be an issue with Maya 2020
The functionality is fine on Maya 2018 and Mudox 2020.
This is a clean install with default prefs.
Wacom tablet is up to date driver.
I tried to copy the Maya 2018 prefs, hoping that there is some setting, however this did not work.
If anyone could help I'd greatly appreciate it.
Best
Replies (48)
Message 21 of 49
amaterasu-qbb
I don't think Wacom is the only one to blame.
My guess is that there may be a relationship between the following that is causing this problem. The more below, the weaker the effect I think.
One case.
  • OS(Windows, macOS, Linux)
  • Software such as Autodesk Maya
  • Wacom
Two cases.
  • OS+Wacom
  • OS + software such as Autodesk Maya
  • Wacom+Autodesk Maya and other software
Or the whole thing is the cause.
I hope it gets better, no matter what the actual cause.
Message 22 of 49
I have the same issue with Maya 2020.4
I use a laptop windows 10 and wacom intuos small tablet.
Will there be a solution?
Message 23 of 49
I am also having this issue in Maya 2020, it is very frustrating. Any help appreciated!
Message 24 of 49
* Correction this fix worked for me! Disable Use Windows Ink.
Message 25 of 49
I'm happy for you. I still have the issue..
Message 26 of 49
akcharly
Turn off the "Windows Inc" and install the latest Wacom Drivers. This helped me to fix the issue on Maya 2020.4
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" повідомленню! | Do you find the posts helpful? "LIKE" these posts!
На ваше запитання відповіли? Натисніть кнопку 'ПРИЙНЯТИ РІШЕННЯ' | Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Андрiй Кривуля | Andrew Krivulya | 3D Grooming Artist - Facebook | Instagram | Twitter | LinkedIN | Youtube | Artstation
Message 27 of 49
Thanks a lot, it works!
Message 28 of 49
dsluna
Observer
Observer
I got the same issu.
Maya 2022, wacom tablet PTH 451/K
The solution for the problem was the same.
Wacom tablet properties > Mapping > Uncheck Use Windows Ink
Good Luck guys!
Message 29 of 49
I was having the same issue but then I enabled...
**Settings -> Pen & Windows Ink -> Let me use my pen as a mouse in some desktop apps**
Control Panel - Pen and Touch -> Pen buttons -> Use the pen button as a right-click equivalent was already enabled.
Restarted Maya 2022 and issue resolved! 😎
Message 30 of 49
aguilera.agustin
Community Visitor
Community Visitor
This fixed the problem for me. Thank you!
Message 31 of 49
nasua.gd
Observer
Observer
I have an ancient Wacom Intuos 3, and this solved the right click issue. I have Maya 2022 and Windows 10. Thank you good sir.
Message 32 of 49
michaeltodd4LMB8
Observer
Observer
I followed all the other suggestions to no avail but I eventually got things sorted after I installed new Video drivers and then uninstalled and re-installed the wacom tablet drivers. THEN right click in 2022 worked again for me. Remember to have a mouse handy after uninstalling the wacom drivers!
Message 33 of 49
It work Only When you use right click, Click on the Tablet AND Drag a little bit in any direction u want without realesing the right click button, then it fully work perfectly in any maya version I hope!
Message 34 of 49
Hi guy
I have same problem and I fixed
In default setting they used pen mode So swap to the mouse mode if you want to use Maya
Maya 2022
one by Wacom
I hope you guy can fix this
Message 35 of 49
jcpantoja
I just uncheck th windows ink option on the driver settings and it's working again.
Message 36 of 49
Hello ! i got same issue on my tablet after few test i probably found a solution you need to deactivate " Windows Ink" on wacom propertie.
Like this :
MayaPen.PNGI hope this work for you, have a good day 😉
Message 37 of 49
Had the same issue with Wacom Intuos. The issue was with the new driver of Wacom 6.3.44. I downgraded to 6.3.43 and it worked fine.
Message 38 of 49
OH MY GOD THANK YOU IT WAS THAT ALL ALONG
Message 39 of 49
alfredo.siordia.g
Thank you. In Maya 2022 I had the same problem. The right click button on my wacom was not working. But this solution fixed that problem. Thanks Again.
Message 40 of 49
thebizon
I've never used a tablet with Maya before today, but I just purchased the Huion Keydial KD200 to replace my Wacom Intuos PT, and I am experiencing exactly the same thing: there is a huge lag with the right-mouse-click function when using the pen and tablet with Maya 2022. I thought it must be the device, so I plugged in my Wacom, and it responds exactly the same way, and only in Maya, and only in the viewport. It works just fine in the Time Slider, so I'm fairly certain it's a Maya issue.
I've turned off Windows Ink, tried every other suggestion offered here, and still get the same result with both devices: a lag of about 1-5 seconds (if it registers at all) when right-mouse-clicking in the viewport. Everywhere else, and in every other program, the right-mouse click works normally.
