I am on a PC
Windows 10
Nvidia Quadro M2200/PCIe/SSE2
Maya 2020.1
For some reason Maya 2020 will not recognize the Right Mouse Button on my Wacom Tablet Pen Intuos Pro.
All I get is a circle with the mouse arrow Icon.
I can get the Functions to work as a Right Click, however as soon as I bring the pen onto the tablet it does not work.
I have tested this with a different Intuos tablet and get the same results.
This appears to be an issue with Maya 2020
The functionality is fine on Maya 2018 and Mudox 2020.
This is a clean install with default prefs.
Wacom tablet is up to date driver.
I tried to copy the Maya 2018 prefs, hoping that there is some setting, however this did not work.
If anyone could help I'd greatly appreciate it.
Best
I don't think Wacom is the only one to blame.
My guess is that there may be a relationship between the following that is causing this problem. The more below, the weaker the effect I think.
One case.
Two cases.
Or the whole thing is the cause.
I hope it gets better, no matter what the actual cause.
I have the same issue with Maya 2020.4
I use a laptop windows 10 and wacom intuos small tablet.
Will there be a solution?
I am also having this issue in Maya 2020, it is very frustrating. Any help appreciated!
Turn off the "Windows Inc" and install the latest Wacom Drivers. This helped me to fix the issue on Maya 2020.4
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" повідомленню! | Do you find the posts helpful? "LIKE" these posts!
На ваше запитання відповіли? Натисніть кнопку 'ПРИЙНЯТИ РІШЕННЯ' | Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.Андрiй Кривуля | Andrew Krivulya | 3D Grooming Artist - Facebook | Instagram | Twitter | LinkedIN | Youtube | Artstation
I got the same issu.
Maya 2022, wacom tablet PTH 451/K
The solution for the problem was the same.
Wacom tablet properties > Mapping > Uncheck Use Windows Ink
Good Luck guys!
I was having the same issue but then I enabled...
**Settings -> Pen & Windows Ink -> Let me use my pen as a mouse in some desktop apps**
Control Panel - Pen and Touch -> Pen buttons -> Use the pen button as a right-click equivalent was already enabled.
Restarted Maya 2022 and issue resolved! 😎
I have an ancient Wacom Intuos 3, and this solved the right click issue. I have Maya 2022 and Windows 10. Thank you good sir.
I followed all the other suggestions to no avail but I eventually got things sorted after I installed new Video drivers and then uninstalled and re-installed the wacom tablet drivers. THEN right click in 2022 worked again for me. Remember to have a mouse handy after uninstalling the wacom drivers!
It work Only When you use right click, Click on the Tablet AND Drag a little bit in any direction u want without realesing the right click button, then it fully work perfectly in any maya version I hope!
Hi guy
I have same problem and I fixed
In default setting they used pen mode So swap to the mouse mode if you want to use Maya
Maya 2022
one by Wacom
I hope you guy can fix this
Hello ! i got same issue on my tablet after few test i probably found a solution you need to deactivate " Windows Ink" on wacom propertie.
Like this :
I hope this work for you, have a good day 😉
Had the same issue with Wacom Intuos. The issue was with the new driver of Wacom 6.3.44. I downgraded to 6.3.43 and it worked fine.
I've never used a tablet with Maya before today, but I just purchased the Huion Keydial KD200 to replace my Wacom Intuos PT, and I am experiencing exactly the same thing: there is a huge lag with the right-mouse-click function when using the pen and tablet with Maya 2022. I thought it must be the device, so I plugged in my Wacom, and it responds exactly the same way, and only in Maya, and only in the viewport. It works just fine in the Time Slider, so I'm fairly certain it's a Maya issue.
I've turned off Windows Ink, tried every other suggestion offered here, and still get the same result with both devices: a lag of about 1-5 seconds (if it registers at all) when right-mouse-clicking in the viewport. Everywhere else, and in every other program, the right-mouse click works normally.
