maya 2020 crashes without error message
Message 1 of 11
please I am in dire need of a hero.
a maya file is corrupted both in autosaves and regular saves. they are saved in ascii format and upon opening the file maya crashes at a percentage without any messages in the maya internal diagnostic tools of my knowledge. i tried the regular stuff, installing new updates, deleting preferences, reinstalling maya altogether, trying it with other computers and versions and i even tried turning on the computer off and on again, however the file will not open.
therefore my guess is, that something in the file itself got corrupted even though i could open the file regularly the last week long. today however the whole last week is lost in saves i can not open it anymore.
i tried pinpointing the error by deleting code from a copy of the ascii file, this has proven quite ineffective because the culled file opens and crashes unpredictably, meaning sometimes i think i have the object which causes the issue but it seems not reliable as it varies.
i am able and willing to provide the file itself and the crashlogs (as much as they exist).
i would love to hear from you, because i would loose 70 hours of work if this is not retrievable.
https://drive.google.com/file/d/1OZavwVtuPT75ksH-Zkz0Hf9W9U2C1V37/view?usp=sharing
i am really in dire need of help and hope right now, so excuse me please tagging people.
@lynn_zhang
@hagen.deloss
@veronica.meuris
i hope all you guys have a nice evening and that some of you can help me. 🙂
Replies (10)
Message 2 of 11
_sebastian_f
in maya try: windows > settings/preferences > preferences > animation > evaluation mode: DG before opening the file.
fun fact: while writing this i tried again with my settings reverted back to parallel and this time it opened without problems....
if that doesn´t work for you i can save and upload my file.
Message 3 of 11
i am really hyped that it can be opened by anyone, so there is hope again. thank you.
this trick doesn't do it for me unfortunately so a saved file from you would be a huge help. 🙂
thanks for taking time out of your day for me
Message 4 of 11
_sebastian_f
here you go.
let me know if it works. there are some nodes not recognized by my system since i don´t have the plugins. if it´s still giving you problems i remove them as well.
Message 5 of 11
i can open it again, thank you very much!
what do you think did it?
my current suspicion is ng-skintools. but also point on curve info and the whole matrix nodes could have done it. i am not sure however. based on what is missing those might be the culprits.
thanks again, and i hope you have a wonderful evening 🙂
Message 6 of 11
mspeer
Hi!
This could be a bug in Maya 2020 and Maya 2020.1.
Maybe you need Maya 2020.2 to open this scene.
Message 7 of 11
veronica.meuris
Hi there,
It sounds like you're having big issues! I'm really sorry for that. I'm a User Researcher and quite removed from product development but have forwarded your message on. I hope that someone will be able to help.
Good luck!
Veronica.
Message 8 of 11
mspeer
Hi!
@veronica.meuris
As far as I see the problem has already been solved.
1) @_sebastian_f  "converted" the scene, so @Anonymous  can now open it again.
2) If this is caused by a bug in Maya 2020 and 2020.1, then it's already fixed since Maya 2020.2 .
Message 9 of 11
kelly_hynes
Hi all,
I took a look at the scene in a text file and could not pinpoint what bug fix has resolved the issue.  But, this issue is resolved in the Maya 2020 updates 2 and 3.
Maya 2020 Update 3 has just been released. @christof.puehringer you should be able to update your Maya 2020 to one of the recent update releases.  Release notes can be accessed here:
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Maya-Rel...
Hope this helps,
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 10 of 11
Maya 2020.2 has the same issues. I will test to open it in Maya 2020.3.
However the fix is, as far as i know at this moment and were able to reproduce, to open the file in an old version of Maya, in my case Maya 2014 but i guess , and then save it again. My guess is that @_sebastian_f has also another older version of Maya, which fixed the problem.
This are all assumptions though.
Thank you for your help guys 🙂
Message 11 of 11
mspeer
Hi!
If I remember correct the scene from @_sebastian_f  was saved with Maya 2020.2.
But there could also be some other issues.
For example I remember one problem with a scene from a user where the only way to open it without any crash was to create first a new scene create a new object and add any deformer and then open the other scene.
So maybe a plug-in needs to be enabled or disabled, or there is any other problem, something like this is hard to troubleshoot.
Sadly I currently don't have the time to look deeper into this.
