Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
I can't see anything in my side view
6 REPLIES 6
yoonyesyoon
504 Views, 6 Replies
I pressed F in the side view penal to focus on the modeling but suddenly my side view went blank.
there is nothing. I can't see modeling or background. other panels still work well but only side view
anybody know how to solve this?
Tags (3)
6 REPLIES 6
mspeer
in reply to: yoonyesyoon
Hi!
Maybe your camera is positioned wrong.
Try to f-ocus your character with hotkey "F".
Also check in Viewport menu
if Show > Isolate Select > ... is used
and try
Show > All
lynn_zhang
Hello @yoonyesyoon ,
Just checking to see if your problem has been solved. Have you tried the above suggestion from @mspeer and did you have any success? If you find it helpful, please click on the "ACCEPT SOLUTION" button in their reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
william.snyder
in reply to: lynn_zhang
Was there a fix for this?
It disappears when I press the f key
chienyih
in reply to: william.snyder
you could also try "Show" in side orthographic, does it showing Curves and Polygons?
n8skow
Fix the focal length in that camera (currently set to 3599).
amaterasu-qbb
in reply to: n8skow
you are right. it's about focal length makes you can't see anything on the scene.
and my opinion is you to try to reset the current workspace. and will it get fixed or not.
