the four view keeps acting weird and showing wrong images and switching between them.. im new to maya .. i need help
video: https://imgur.com/dPaSSHv
Solved by sean.heasley. Go to Solution.
Hi @Anonymous and welcome to the community!
A quick test you'll want to try is deleting your settings/preferences.
From there you'll want to also make sure that each image plane is checked to "display in one viewport only" so they aren't showing in the perspective viewport (unless you want that).
You'll also want to check the far and near clipping plane values of each camera to make sure they aren't causing any issues.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided on Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
