Maya 2018 shortcut key combination problems
jtdx8866
jtdx8866
So I have set my transform constraint shortcut like this:
Surface slide: Ctrl+shift+x
edge slide: shift+x
off: Ctrl+alt+x
However, for the "ctrl+shift+x" combination, the shortcut only works when I am holding all the buttons.  As soon as I release the button, it suddenly went back to the previous constraint. I have changed the "on press" and "on release" option and none of them works.
I am pretty sure that the "ctrl+shift" combination is broken because I have tried the same settings in Maya 2017 and this problem doesn't happen
Replies (7)
sean.heasley
Hi @jtdx8866 and welcome to the community!
I just tried this and had no issues with the hotkeys working.
If you try these same combinations but with a different command other than Surface Slide does this still occur?
Also, you may want to try deleting your settings/preferences so the hotkeys are completely reset and then try setting them again.
Let me know if anything changes!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @jtdx8866
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
jtdx8866
Hi Sean,
 Sorry for the late reply. I just tried your suggestions but the problem still exists. It is really weird that even if I am using the default shortcut without assigning any keys to the selection constraint if I am pressing ctrl+shift together, it will become " edge slide", if I let go, the option will become "off" again. I tried in 2017 and that doesn't happen
sean.heasley
Hi @jtdx8866
Hmmm ok. And resetting your prefs didn't solve the issue?
Out of curiosity, could you try changing the hotkeys to a simply one key press? For example the letters A, B and C. I'd like to make sure its an issue with that specific key combination and not your hotkeys entirely.
jtdx8866
https://forums.autodesk.com/t5/maya-modeling/move-rotate-scale-edge-slide-on-by-default/td-p/7330429
I think I am just having the same issue was mentioned in this thread. I am sure it is not fixed by deleting or renaming the prefs folder. Right now I am updating my Maya 2018 to update 2, I will let you know if that bug still exists.
Thank you!
jtdx8866
Hi @sean.heasley, it is fixed in update 2, thank you for your concern!
sean.heasley
Awesome! Thanks for letting me know!
