Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2018 rigging light bend deformer
8 REPLIES 8
Message 1 of 9
stewing_gum
440 Views, 8 Replies
Hi folks !
I need your help about a rigging problem. I want to add some lights on the wing of my plane, that's will fallow the bend of the wing.
But even if i put on the group wich is declare/ group to the bend folder it's not fallowing as i want. Do you have any ideas, tips or other way to do it like i want ?
Thanks !
Labels (1)
8 REPLIES 8
Message 2 of 9
jdswiney
in reply to: stewing_gum
You are going to want to try a Rivit. Then you can put the light under the locator it creates.Rivit should be under the constrain menu but I can't remember if that's were it was in 2018
Message 3 of 9
stewing_gum
in reply to: jdswiney
Thanks for this solution ! i have maya 2018, and it don't exit. i'll try to update my maya and keep you in touch, thanks !
Message 4 of 9
stewing_gum
So your idea work with the constraint " point on poly" in maya 2018. And it work only with an Arnold meshlight, not with area light, but it's enough  for me, so thanks so much for your help !
Peace
Message 5 of 9
jdswiney
I guess that would be why I can't remember where they were in 2018. LOL
You might want to check out these links. This was the way to do in the
past. I guess that it wasn't as long ago as I remember.
https://vimeo.com/183502262?embedded=true&source=video_title&owner=35819904
https://lesterbanks.com/2017/07/make-maya-rivet-matrix-nodes/
Message 6 of 9
jdswiney
In theory I would think so but I have never been able to get it to work
the way a rivit does.
Message 7 of 9
jdswiney
Wait. Yes you should be able to do what you are trying to do.  If you Point On Poly a locator with maintain offset off and then parent the light to the locator it should work. So maybe give that a try.
Message 8 of 9
stewing_gum
yes it's works perfectly !
thanks so much !
Message 9 of 9
jdswiney
You are welcome. Good Luck!
