Maya 2018 nothing appears in viewport
I TRY TO BUILD POLYGONS BUT NOTHING APPEAR.
Hi @Anonymous your title 'why I CANNOT BUILD MODELS IN MAYA 2018' was edited for clarity by @sean.heasley
Mark.Lancaster
@Anonymous
This forum is about installation and licensing issues not why things are not working in a given Autodesk Application.  Please post over in the Maya forum
Mark Lancaster
sean.heasley
Hi @Anonymous
Can you post your hardware specs so I can make sure your machine is compatible with Maya?
Also you may want to check to make sure all your drivers are up to date as well!
Let me know if anything changes!
sean.heasley
Hi @Anonymous
I'm just checking in to see if you need more help with this. If you get a chance, please let me know what your specs are and if your drivers are up to date!
If  your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
