Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2018 models disappeared from viewport
4 REPLIES 4
1584 Views, 4 Replies
I created a Scene in Maya 2018.  To continue my further modeling I hid the objects I created and Continued my Modeling.  I put the previous models in layers.  But when I tried to unhide those objects I am unable to find the objects,  In the outliner I see only transform of those objects.  Please need help to recover those objects.  The models are too many.  I am doing it for my projects.  thanks in advance
Hi @Anonymous your title 'models missing' was edited for clarity by @sean.heasley
4 REPLIES 4
sean.heasley
Hi @Anonymous
Can you see other objects and just not certain models or can you not see any of them? You may want to check to make sure you aren't in Isolate select mode.
If that doesn't help, when you get a chance can you please post some screenshots and/or zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
Let me know if anything changes!
sean.heasley
in reply to: sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Please check the file i attached.  Still I have the problem.
mspeer
Hi!
There are only some Intermediate input meshes (in history) for your boolean operations that i made visible, there is not more in the scene.interm.gif
