Hi, ive been having problems with Maya 2018's Hypershade. Whenever i attempt to open it, the shader balls show up for a split second then disappear. Then the only thing that shows up is text saying "Press Tab to create a node." With this always showing up i am unable to creat renders and animations with the correct shading and coloring and what not. Please help me out!
Hi @Anonymous your title 'Hypershade not working properly" was edited for clarity by @sean.heasley
Hi @Anonymous and welcome to the community!
What GPU are you using and are the drivers the same as our certified hardware list?
You can find our certified hardware list here!
If that doesn't help, you may want to try deleting your settings/preferences.
Please let me know if anything changes!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
Hope you are doing well! 🙂 Just wanted to check in and see if you had a chance to review @sean.heasley 's suggestions? Any success? New issues?
Happy to help in any way we can!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
