I've had some crashing issues in the past with Maya, but this is unreal. Like within 2 minutes it locks up over and over. Is there a patch or anything out? Or should I try to reinstall?
Hi @ClintPositive and welcome to the community!
We need a bit more information to see how we can help you.
Steps to find your pc specs can be found here!
Steps to update your drivers can be found here!
When you get a chance please come back and provide us with as much information as possible!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
I have one of the Cintiq Companion 2's and the I just downloaded the student trial version of Autodesk Maya 2018
Thanks for coming back with your system specs.
Maya should be able to run fine on your Cintiq so I just want to get a bit more information.
Are there any reproduce able steps that are causing your crash?
Does it crash on an empty scene of Maya or a scene you've been working on?
Please come back with as much information as possible when you get the chance!
All the best,
Sean Heasley
Just checking in again to see if you're still having this issue. When you get a chance, please come back with more information so I can help you further!
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
Hi Sorry Sean!
Ya, it seems to happen when I'm working in scenes for animation. It just locks up and you can't do anything. I'd say over the last 2 weeks, with 3 different scenes I'm working on, it's locked up/crashed around 25 times maybe. I guess I'll just have to get used to it. I guess what I'm hoping for is an update or patch release or if it's been released. My Autodesk Desktop App doesn't seem to offer anything, so I guess I could try reinstalling everything...
When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
Let me know if anything changes!
All the best,
Sean Heasley
Just wanted to check in to see if you needed any more help with these crashes. When you get a chance, can you please zip and attach the scene file here so I can take a look at it?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
