Maya 2018 can't launch with blank output window???
moonyuet
Observer Observer
Message 1 of 9
moonyuet
Observer
Observer
I've downloaded Maya 2018 Student version for a year. And It ran smoothly up till today. I can't launch maya 2018 with a blank output window as a result. Can anyone tell me how to solve this problem? I have spent like more thaan 3 hours to figure out the solutions but they won't help.
Replies (8)
Message 2 of 9
sean.heasley
Hi! What are the hardware specs of your machine? Also, what GPU are you using and are the drivers up to date? Finally, have there been any major updates to your OS or firwall/anti-virus that might be causing this issue? Please let me know if anything changes!
Message 3 of 9
moonyuet
Observer
Observer
Processor is Core i7-6700HQ Quad-Core Processor with Hyper-Threading 2.6 GHz GPU is Nividia Geforce GTX 970M Operating System is Window 10 64-bit Storage is 512 GB SSD
Message 4 of 9
sean.heasley
Hi! Your GPU isn't on our certified hardware list so that could be causing the issue. I'd highly recommend making sure the drivers are up to date. If that doesn't work, you may want to try a clean uninstall/reinstall of Maya. Steps on how to do that can be found here: https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
Message 5 of 9
sean.heasley
Hi! Just wanted to check in to see how things were going. Are you still having this issue?
Message 6 of 9
moonyuet
Observer
Observer
in fact i have tried these two solutions before. But it doesn't work. I think it's my graphic card problem. I can't open any other 3D applications or OpenGL-based software such as Photoshop, Substance Designer, and Houdini.
Message 7 of 9
Use DDU (Display Driver Uninstaller) and completely remove the NVIDIA driver. Then reboot and reinstall it. I usually uncheck GeForce experience and I never update through it. I recommend 388.71, but you can always try the latest 39X release. If you also run DaVinci Resolve 15 you’ll need 390+.
I can confirm, however, that the 970M works totally fine with Maya 2016, 2016.5, 2017, and 2018. My laptop of 3 years has been going strong with it 🙂
Cheers,
Mike
Message 8 of 9
sean.heasley
Hi @moonyuet
It does definitely sound like a GPU issue but the steps @Anonymous provided are great and should help you out.
Have you had a chance to try them?
Message 9 of 9
I do have the same problem with maya 2017 and 2018 I even try to download the 2016 but when installed it's not working either. Some day when I'm starting my computer it's working pretty well but if I close the window of Maya and I wanna reopen it I'm having the blank output windows popping up and nothing happen. And some other days like now, When I lunch it nothing happen but the output window.
I tried to lunch Maya as an Administrator and it's changing nothing, I updated all my drivers, I'm running out of ideas.....
I have an I7 6700k, a NVidia GTX 1070 and 16 Go of RAM
