Maya 2018 Camera based selection error
sean.heasley
Hi @Anonymous
What GPU are you using and is the driver version the same as our certified hardware list?
You can find our certified hardware list here!
Also what version of Maya are you running and is it up to date?
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
