- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I get an unhandled Exception, when using Maya 2018.4 Student Version.
I can easily reproduce it:
- creating a Polgon Cube
- in the Settings changing the Parameters like Height, Width or Depth
- then when trying to click on edit undo or using shortcut Ctrl+Z
the programm crashes.
But the error occures as well sometimes when selecting faces/vertices/edges.
Sometimes the program just closes without any Error Alert.
The Output Window shows the following Message:
Stack trace:
Foundation.dll!TmtRefCounter::add
Foundation.dll!Tstring::Tstring
CommandEngine.dll!TcommandObject::commandString
CommandEngine.dll!TundoManager::getUndoCmdName
CommandEngine.dll!TundoInfoAction::doCommand
CommandEngine.dll!TmetaCommandPtrArray::catenate
CommandEngine.dll!TminMelArgList::nextDigit
CommandEngine.dll!SophiaExecutable::evaluate
CommandEngine.dll!TcommandEngine::executeCommand
ExtensionLayer.dll!QmayaMenuItem::version
CommandEngine.dll!TmelVariableList::`default constructor closure'
CommandEngine.dll!melScanDouble
ExtensionLayer.dll!TscriptAction::execute
ExtensionLayer.dll!TmenuScriptAction::doIt
ExtensionLayer.dll!Taction::performAction
ExtensionLayer.dll!Taction::doIt
Qt5Core.dll!QMetaObject::activate
Qt5Widgets.dll!QMenu::popup
Qt5Widgets.dll!QMenuBar::platformMenuBar
Qt5Widgets.dll!QMenuBar::setCornerWidget
Qt5Widgets.dll!QMenuBar::mousePressEvent
Qt5Widgets.dll!QWidget::event
Qt5Widgets.dll!QMenuBar::event
Qt5Widgets.dll!QApplicationPrivate::notify_helper
Qt5Widgets.dll!QApplication::notify
ExtensionLayer.dll!TwindowManager::windowPreferencesAreEnabled
Qt5Core.dll!QCoreApplication::notifyInternal2
Qt5Widgets.dll!QApplicationPrivate::sendMouseEvent
I added the Crashlog and the User Info as Attachments.
I'm using a Nvidia 1060 in my Laptop and tried several drivers.
At last I tried the recommended driver version 398.82.
The Computer itself is the MSI GE63 Raider RGB 8RE.
I hope anyone has an Idea how to fix this problem.
Kind Regards
Jonas Sorgenfrei
