Hello List,
Maya 2017 Update 4 freezes on startup for about 10-20 sec. SysInternals are showing me that this is caused by an unsuccessfull connection to the internet - which is blocked by our firewall. It seems this connection is used for the SignIn introduced in 2017!? How can I deactivate this 'feature'? IT will NOT open this connections so I need a solution to prevent artists from waiting 10-20 sec. each time there start maya.
Kind Regards, Florian
Solved by sean.heasley. Go to Solution.
Hi @Anonymous and welcome to the community!
You can try following the steps here.
Let me know if this solves your issue!
Please hit the Accept as Solution button if my post fully solves your issue, or reply with additional details if the problem persists.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
