Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2017 update 3 layered texture broken
7 REPLIES 7
Message 1 of 8
1037 Views, 7 Replies
Layeredtexture node seems to be broken since Maya 2017 Update 3. The alpha inputs of the layered texture do not work.
1: Create ramp or file node
2: Create layeredTexture node
3: Connect ramp1.outColor.outColorR to layeredTexture1.inputs.alpha
And now you see that the layeredtexture thumbnail doesn't update with the alpha, with rendering it also doesn't work.
We are using linux.
We are using linux.
7 REPLIES 7
Message 2 of 8
Seems like the alpha of a file node is also broken?
Message 3 of 8
mspeer
mspeer
Hi!
Here it works in Viewport and in Rendering, maybe you use a combination of nodes that isn't supported in the Renderer you use.
Please upload a scene-file.
Hi!
Message 4 of 8
in reply to: mspeer
Found out that only the thumbnail is broken, it does render in my current test.
Message 5 of 8
mspeer
mspeer
Hi!
You are right, the rendered icon does not reflect connected "alpha textures".
You can report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
Hi!
Message 6 of 8
Nadja.Bueckmann
in reply to: mspeer
Nadja.Bueckmann
Hi @Anonymous,
I reported the issue to our development department.
They are now having a look into it.
Best, Nadja
Nadja Bueckmann
Technical Support Specialist – M&E (3ds Max, Maya)
Hi @Anonymous,
Best, Nadja
Nadja Bueckmann
Message 7 of 8
tim.reed
in reply to: Nadja.Bueckmann
tim.reed
Community Visitor
Community Visitor
They are no longer working in Legacy Viewport as well.
Message 8 of 8
in reply to: tim.reed
still broken in Update 4
