Announcements
Maya 2017 Unable to Batch Render Certain Parts of a Scene with Mental Ray
agentredgirl
Message 2 of 11
agentredgirl
So I have a fairly large scene with animation, small xgen interactive grooms (eye lashes and eyebrows), and some simple nhair dynamics going on. I basically have 2 characters and when I attempt to batch render, it went just fine when character 1 was in the camera. However, when the camera switched to character 2, the batch render either crashes or will just never start. I am not sure if it is related, but I am also getting this error, "valence 138 exceeds max boundary valence of 20"
I have tried Optimizing my Scene and deleting unknown nodes, deleting my prefs folder, restarting my computer, updating my graphics card... I just dont know what to do.
Here is my actual render log as well... any help would be greatly appreciated because I just literally have no idea what to do.
Starting "C:\Program Files\Autodesk\Maya2017\bin\mayabatch.exe"
mental ray for Maya 2017
mental ray: Found 1 GPU with vendor's API.
mental ray: Found 1 CUDA device.
mental ray: version 3.14.3.31, 16 Nov 2016, revision 281811
mental ray: started on "DESKTOP-VRON8T1", Mon Oct 30 13:12:48 2017
mental ray: Identified file "architectural.so" as identical to "architectural.dll"
mental ray: Identified file "paint.so" as identical to "paint.dll"
mental ray: Identified file "subsurface.so" as identical to "subsurface.dll"
mental ray: Identified file "layering.so" as identical to "layering.dll"
Initialized VP2.0 renderer {
Version : 2016.3.78.11. Feature Level 5.
Adapter : GeForce GTX 1080 Ti/PCIe/SSE2
Vendor ID: 4318. Device ID : 6918
Driver : .
API : OpenGL V.4.6.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 11264 MB.
CPU Memory Limit: 62219.3 MB.
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
0: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 9.1.75.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
OpenCL evaluator is unable to find a GPU device that can share VBOs with OpenGL.
pymel.core : INFO : Updating pymel with pre-loaded plugins: mayaHIK, invertShape, GamePipeline, curveWarp, CloudImportExport, tiffFloatReader, poseInterpolator, bifrostvisplugin, hairPhysicalShader, ATFPlugin, Mayatomr, cacheEvaluator, ikSpringSolver, ik2Bsolver, xgenToolkit, AbcExport, retargeterNodes, gameFbxExporter, VectorRender, OpenEXRLoader, lookdevKit, Unfold3D, Type, renderSetup, fbxmaya
Maya 2017 importing module pymel 1.0.9 (C:\Program Files\Autodesk\Maya2017\Python\lib\site-packages\pymel\__init__.py)
Error: file: C:/ProgramData/Autodesk/ApplicationPlugins/MayaBonusTools-2014-2017/Contents/scripts-2017/bonusToolsMenu.mel line 1670: UI commands can't be run in batch mode.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "JSNormalMapper_2009_32", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "HSVadjust2", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "CorrectiveShape70", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "BPT_Bevel", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "3delight_for_maya2011", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "AM_Velvet", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "AM_Glossy_30", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "ByronsPolyTools", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "FumeFX", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "mtorsubdiv", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "FurryBall_2009", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "weightDriver", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "JSNormalMapper_2008_64", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "shaveNode", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "JSNormalMapper_2009_64", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "MayaMan_m4", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "NormalBump2D", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "moebiusPass", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "RenderMan_for_Maya", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya2008", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya2009", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya60", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "finalRender", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya70", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya80", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya85", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "syflex", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "bfcLookDev", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "am_metaballs", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "bctrial16_maya2008", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "cartoonShader50", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "correctShape2013x64", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "elastikSolver", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "libCausticMap", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "libSkinA", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "libSkinShader", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "magicAssetNode.py", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "maxwell", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "ngSkinTools", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "md_RayDiffuse", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "pdiMaya2x", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "rpmaya", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "skinShapeDeformer", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "vrayformaya2008", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "xfrog", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "xfrog4.0", was not found on MAYA_PLUG_IN_PATH.
File read in 12.2 seconds.
Result: E:/Programs/System/System/Projects/MAYA/AMothersLove/Scene101test__9492.mb
Warning: int $interactive = 1; // for Flag -interactive
Warning: "C:\Users\User\AppData\Local\Temp\ASTCBB688.tmp" line 9.21 : Redeclaration of variable "$interactive" shadows previous declaration at line 7. Previous value will be overwritten by explicit initializer.
valence 48 exceeds max boundary valence of 20
valence 30 exceeds max boundary valence of 20
Replies (10)
Message 1 of 11
agentredgirl
Hello! I am trying to batch render a scene and I keep getting this error. I am not sure how to fix this. I am not sure if it is related, but I cannot batch render this section of my animation either.
valence 138 exceeds max boundary valence of 20 (It says this almost 100 times)
valence 30 exceeds max boundary valence of 20 (it says this about half as many times)
Any help with this would be greatly appreciated.
Message 3 of 11
sean.heasley
Hi @agentredgirl
Did you happen to do any converting of Poly to Subdiv or vice versa? This error isn't that common but I've seen it in the past and it is usually related to the valence of a vertex is how many edges are connected to it.
If you go to conver to Poly to Subdiv you'll see an option that says 'Maximum Edges per Vertex'. You could try increasing that and see if the error still occurs.
However if you aren't converting anything and still seeing the error, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
Let me know if anything changes!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 4 of 11
agentredgirl
Sean,
Thank you... I am not sure what to do =( My primary concern is getting this to batch render. It simply wont even when I used a command line script.
Here is a link to the scene file:
https://drive.google.com/open?id=0Bx1HNi1dvx5HWVc3RXhQUklWQmc
Message 5 of 11
sean.heasley
Hi @agentredgirl
Thanks for attaching the scene file! I'm receiving the same error however I'm also getting a lot of errors for the missing xml files.
Like how you attached the scene file via google drive, Is it possible you could attach the entire project folder here so I can see if anything is wrong or missing that may be causing the issue? If the project folder is confidential or you don't want the general public to have access, feel free to send it to me in a private message and I'll look further into this issue!
Message 6 of 11
agentredgirl
Sean,
The XML files are just dynamic caches... I dont think they would have anything to do with it. Even when I disable or delete them all, the scene still wont batch render =(
Message 7 of 11
agentredgirl
Is there a script that would allow me to batch render and save files from a camera using the renderview render? I can do regular renders just fine
Message 8 of 11
sean.heasley
Hi @agentredgirl
There is a python command that allows you to batch render through the render view window. Here's the steps below as well!
(Note: You'll need to change the start and end frame based on what you want to render.)
Run the following python command in Maya in a python tab. Edit the startFrame and endFrame variables to match the production needs:
import maya.cmds as cmds
import maya.mel as mel
startFrame = 0
endFrame = 24
mel.eval('currentTime %s ;'%(startFrame))
while(startFrame < endFrame):
    mel.eval('renderWindowRender redoPreviousRender renderView;')
    startFrame += 1
Please let me know if this helps solve your issue or if you need any more assistance!
Message 9 of 11
agentredgirl
Thank you Sean! Just two more questions... if thats ok.
Is it possible to select a camera with that python command by chance?
Also, I made some changes and checked my render log again and got this. Does any of this mean anything to you?
Stack trace:
xgenToolkit.mll!TiteratorWrapperFwd<TmultiIndexDependNodeSet::NodesOfTypeConstIteratorDescriptor,TiteratorWrapper<TmultiIndexDependNodeSet::NodesOfTypeConstIteratorDescriptor> >::operator=
OpenMaya.dll!THdependNode::computePlug
DependEngine.dll!TdependNode::dbEvaluate
DependEngine.dll!TdependNode::mpSafeDbEvaluateWithSet
DependEngine.dll!Tplug::processEval
DependEngine.dll!Tplug::evaluateValue
DependEngine.dll!TdataBlockDG::value
OpenMaya.dll!MDataBlock::inputValue
DependEngine.dll!TevaluationNode::evaluateDirtyPlugs
DependEngine.dll!TevaluationNode::taskEvaluation
DependEngine.dll!TserialExecution::evaluateSchedule
DependEngine.dll!TserialExecution::taskEvaluation
DependEngine.dll!TdrawDbChangeTracker::setListeningToSource
DependEngine.dll!TdrawDbChangeTracker::GetTracker
MSVCP110.dll!std::_Pad::_Release
MSVCR110.dll!_beginthreadex
MSVCR110.dll!_endthreadex
KERNEL32.DLL!BaseThreadInitThunk
ntdll.dll!RtlUserThreadStart
Result: C:/Projects/AML/AML/scenes/Scene101test__9040.ma
Fatal Error. Attempting to save in C:/Users/User/AppData/Local/Temp/User.20171031.1009.ma
Error: file: C:/Program Files/Autodesk/Maya2017/plug-ins/xgen/scripts/xgen.mel line 1071: TypeError: file C:\Program Files\NVIDIA Corporation\mentalray 3.14 for Maya 2017\scripts\mentalray\xgenmr\main.py line 47: Flag 'selection' must be passed a boolean argument
Message 10 of 11
agentredgirl
The script only renders the perspective camera for some reason
Message 11 of 11
sean.heasley
Hi @agentredgirl
Unfortunately I don't recognize anything immediately with that new log.
However I do have an idea about the script. If you go to Panels->Perspective you can change it from the set perspective camera to one of your cameras in the scene. Can you try that and run the script to see if it renders from that camera?
