- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So I have a fairly large scene with animation, small xgen interactive grooms (eye lashes and eyebrows), and some simple nhair dynamics going on. I basically have 2 characters and when I attempt to batch render, it went just fine when character 1 was in the camera. However, when the camera switched to character 2, the batch render either crashes or will just never start. I am not sure if it is related, but I am also getting this error, "valence 138 exceeds max boundary valence of 20"
I have tried Optimizing my Scene and deleting unknown nodes, deleting my prefs folder, restarting my computer, updating my graphics card... I just dont know what to do.
Here is my actual render log as well... any help would be greatly appreciated because I just literally have no idea what to do.
Starting "C:\Program Files\Autodesk\Maya2017\bin\mayabatch.exe"
mental ray for Maya 2017
mental ray: Found 1 GPU with vendor's API.
mental ray: Found 1 CUDA device.
mental ray: version 3.14.3.31, 16 Nov 2016, revision 281811
mental ray: started on "DESKTOP-VRON8T1", Mon Oct 30 13:12:48 2017
mental ray: Identified file "architectural.so" as identical to "architectural.dll"
mental ray: Identified file "paint.so" as identical to "paint.dll"
mental ray: Identified file "subsurface.so" as identical to "subsurface.dll"
mental ray: Identified file "layering.so" as identical to "layering.dll"
Initialized VP2.0 renderer {
Version : 2016.3.78.11. Feature Level 5.
Adapter : GeForce GTX 1080 Ti/PCIe/SSE2
Vendor ID: 4318. Device ID : 6918
Driver : .
API : OpenGL V.4.6.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 11264 MB.
CPU Memory Limit: 62219.3 MB.
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
0: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 9.1.75.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
OpenCL evaluator is unable to find a GPU device that can share VBOs with OpenGL.
pymel.core : INFO : Updating pymel with pre-loaded plugins: mayaHIK, invertShape, GamePipeline, curveWarp, CloudImportExport, tiffFloatReader, poseInterpolator, bifrostvisplugin, hairPhysicalShader, ATFPlugin, Mayatomr, cacheEvaluator, ikSpringSolver, ik2Bsolver, xgenToolkit, AbcExport, retargeterNodes, gameFbxExporter, VectorRender, OpenEXRLoader, lookdevKit, Unfold3D, Type, renderSetup, fbxmaya
Maya 2017 importing module pymel 1.0.9 (C:\Program Files\Autodesk\Maya2017\Python\lib\site-packages\pymel\__init__.py)
Error: file: C:/ProgramData/Autodesk/ApplicationPlugins/MayaBonusTools-2014-2017/Contents/scripts-2017/bonusToolsMenu.mel line 1670: UI commands can't be run in batch mode.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "JSNormalMapper_2009_32", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "HSVadjust2", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "CorrectiveShape70", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "BPT_Bevel", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "3delight_for_maya2011", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "AM_Velvet", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "AM_Glossy_30", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "ByronsPolyTools", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "FumeFX", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "mtorsubdiv", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "FurryBall_2009", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "weightDriver", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "JSNormalMapper_2008_64", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "shaveNode", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "JSNormalMapper_2009_64", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "MayaMan_m4", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "NormalBump2D", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "moebiusPass", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "RenderMan_for_Maya", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya2008", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya2009", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya60", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "finalRender", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya70", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya80", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya85", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "syflex", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "bfcLookDev", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "am_metaballs", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "bctrial16_maya2008", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "cartoonShader50", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "correctShape2013x64", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "elastikSolver", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "libCausticMap", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "libSkinA", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "libSkinShader", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "magicAssetNode.py", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "maxwell", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "ngSkinTools", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "md_RayDiffuse", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "pdiMaya2x", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "rpmaya", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "skinShapeDeformer", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "vrayformaya2008", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "xfrog", was not found on MAYA_PLUG_IN_PATH.
Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "xfrog4.0", was not found on MAYA_PLUG_IN_PATH.
File read in 12.2 seconds.
Result: E:/Programs/System/System/Projects/MAYA/AMothersLove/Scene101test__9492.mb
Warning: int $interactive = 1; // for Flag -interactive
Warning: "C:\Users\User\AppData\Local\Temp\ASTCBB688.tmp" line 9.21 : Redeclaration of variable "$interactive" shadows previous declaration at line 7. Previous value will be overwritten by explicit initializer.
valence 48 exceeds max boundary valence of 20
valence 30 exceeds max boundary valence of 20
